588,644 active members*
4,942 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Face milling for best finish on 4340 steel alloy on spline surface
    Sep 2008
    17
    I am machining a vertical surface 2" tall that follows a gradual spline profile using a Haas VF2SS vertical CNC mill and looking for the best possible finish. The material is 4340 annealed. I have tried a high performance 4 flute 20mm coated carbide cutter but I am not satisfied with the finish. I can't surface grind the piece because of the spline profile.
    Does anyone have a recommendation for an end mill, an insert cutter or process that can give me a superior surface on 4340 with a finish grade N8 (125 micro-inch) or better that is truly perpendicular (no taper) to the horizontal surface.
    Thanks for your ideas!
    Aug 2007
    147
    What speeds and feeds are you running? Are you getting chatter?
    Consider trying a variable flute EM like a Hanita Varimill. A milling chuck may help as well... the more rigid, the better.
    Sep 2008
    17
    Glacem,
    Many thanks for your ideas. I am going to try the Verimill cutter and an accurate milling chuck.
    As for feeds and speeds, I have tried everything but my best results were using a 0.5" end mill 4 flute at 4000 rpm at 7 IPM. Is not the spec for the material but yields the cleanest finish.
    I suspect it is chatter issue and I know it's not coming from the work piece so your suggestion on the mill and holder is promising.
    I will let you know the outcome. I am also planning to try and electro-polish the piece when it's done to see that can do. Thanks again.
  1. computation for surface finish in milling
    By uperez in forum MetalWork Discussion
    Last Post: 06-21-2007, 09:33 PM
  2. Bad surface finish with 3-D milling
    By dylskee in forum Haas Mills
    Last Post: 06-15-2007, 12:09 AM
  3. 3D Milling Surface Finish Problem
    By TurboME in forum MetalWork Discussion
    Last Post: 12-18-2006, 05:32 AM
  4. Surface finish after milling a mold ?
    By Shizzlemah in forum Moldmaking
    Last Post: 11-25-2006, 03:31 AM
  5. RFQ: 35 parts 4340 steel
    By Eddieweeks in forum Employment Opportunity
    Last Post: 08-21-2006, 05:17 PM
