603,798 active members*
2,460 visitors online*
Results 1 to 5 of 5
    Jun 2011
    3
    FADAL 2216 help
    We are gettting X and Y axis 410 servo alarms during cuts. Seems to happen when load meter hits around 30% on the spindle. Just before the alarm comes up there is a loud squeal like its trying to force the the axis to move. Any help or suggestions as to what may be causing this, or a solution to this problem would be greatly appreciated.
    Jun 2011
    David deCaussin
    Hi
    There are a few things to check. Make sure the waylube pump is operating properly. Next check your x axis way covers are not binding up. What type of tooldoes this happen with. High spindle loads put a big load on the axis motors. At times the amplifiers are actually working in reverse as the have to resist the load the cutting tool is generating. Can't think of anything that would cause a squeeling sound. Could be a loose coupling between the Motor and ballscrew. I would suggest you pull the way cover off the right side of the table, then jog the x axis untill you can put your hand on the ballscrew. Then hit emergency stop. With your hand on the ballscrew you should be able to rotate the ball screw with very little effort. For the Y axis jog the y in the plus direction. Climb in the encloser, pull the telescoping ball screw cover back and rotate the y ballscrew with the emergency stop pushed. Think the problem may be a bad ballscrew. Good luck
    Aug 2006
    52
    Welcome David (the "D" in FADAL)! We appreciate any insight you might bring to discussions on the board.
    Jun 2011
    First I have to figure out how this system works. Haha
    Mar 2003
    900
    Hello David-- Haven't heard from you for a while Good to see your still in the game.
    Neal D.
  1. Defining part origins on a 2216?
    By slick_ride in forum Fadal
    Last Post: 01-07-2010, 10:41 PM
  2. 2216 FX Run spindle with door open???
    By Chuck Pressure in forum Fadal
    Last Post: 10-26-2009, 03:26 PM
  3. Replies: 23
    Last Post: 11-17-2008, 10:28 PM
  4. VMC 2216 Thrust Bearings and/or Ball Screw
    By Billet Sean in forum Fadal
    Last Post: 08-30-2008, 02:25 PM
  5. 2216 FX
    By fourperf in forum Fadal
    Last Post: 01-18-2008, 04:38 PM
