587,197 active members*
2,744 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal CNC control replacment
Results 1 to 5 of 5
    Nov 2015
    23
    Power Automation | PC-based CNC Control, CNC System, Soft CNC
    I came across this from MMS today.
    I would like to know if any Fadal users have upgraded there machines to this control?
    If so , what advantages have you seen in this upgrade?
    Thanks for any feed back.
    Gord
    Jun 2017
    13
    Re: Fadal CNC control replacment
    We upgraded one of our machines to a similar control made by Numatix and it has been nothing but a headache. it is hard to use and the only service they have is in 2000 miles away. Meanwhile our other two Fadals have been running no problem.
    Apr 2005
    1194
    This year there is
    Calmotions 527F (Couple of the original Fadal guys sons, uses Ethernet instead of the back panel board for quick data between card $8000.00
    NXGEN (Dave Decausin Jr. (The D's son in fadal) has a version of Flashcut for Fadal...replaces the entire control and pendant) $15,000.00
    Power Automation (Replaces the entire control and pendant) $17,000.00
    All look very promising.
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Apr 2005
    1194
    Quote Originally Posted by Thad92 View Post
    Numatix it appears was a version of the original Rubicon that was developed by a software engineer that is long dead. At some point there was Cincinnati CNCs that had the revolution control that was another version of that control. Its sad to see a fadal get retrofitted and then not work. You know the old control as slow as it is ....is super reliable.
    Jan 2015
    417
    Calmotions 527F simple easy to do do all new cards , no learning curve at all
  1. Replies: 3
    Last Post: 09-21-2014, 01:04 AM
  2. PM-45 X/Y handle replacment
    By jroberts1968 in forum Benchtop Machines
    Last Post: 07-04-2011, 11:15 PM
  3. Fadal Control
    By kreed in forum Community Club House
    Last Post: 01-01-2011, 06:41 PM
  4. replacment monitors
    By cb1 in forum Computers / Desktops / Networking
    Last Post: 03-02-2010, 11:58 PM
  5. Replacment parts
    By Legion99999 in forum Syil Products
    Last Post: 10-05-2008, 07:27 PM
