Ebay listing here: Fadal VMC20 No Reserve $1 Starting Bid Powered and Running | eBay
Video of machine cutting parts made 10/10/14:
FADAL VMC20 FOR SALE - YouTube
We still use this machine but we have to make room for a new wire edm machine that we bought so It's gotta go! Everything works fine as far as I know. It appears to be wired for a forth axis also. I can look into this further if this is a feature you really want. You can come take a look at it and see it run if you like.
The machine has an internal transformer so it can use any standard 3 phase voltage. We bought this machine a few years back and it has been a good work horse. It was previously owned by Bobcat. The spindle rpm seems to run faster than programmed, but this has never bothered us. It could be adjusted on the Baldor spindle drive in the back cabinet if needed.
Here are the specs I found on the net. Don't hold me to them:
SPECIFICATIONS:
X-Axis Travel : 20"
Y-Axis Travel : 16"
Z-Axis Travel : 20"
Table Size : 29.5'' x 16"
Spindle Speed : 75 - 6000 RPM
Spindle Taper : # 40
Spindle : 7.5 HP
Approx Machine Weight : 7,500 lbs
EQUIPPED WITH:
Fadal CNC88 Control
RS-232 Port
Coolant System
Full Enclosure
16 Station ATC
Buyer is responsible for all loading and trucking. We will
disconnect and bring the head down on a block of wood for
shipping.
