Re: Fadal vmc 15 tapping torque
The bottom line, with the 10 HP motor you have about 37 to 55 ft of torque to work with.
Not all spindle drives are the same, the Baldor drive is one of the top performers, Mitsubishi was the least.
At the original Fadal, I worked with most of the drive manufactures and developed the rigid tap control feature back in 1991.
You can put a AC clamp-on meter to measure how much current is actually going out to the motor. You should see about 30 amps before it stalls. The rule of thumb is 3 amps per Horse Power.
With the VMC15, it is a cogged belt so it never slips the motor can just stall.
The High/Low 10K drive is mechanically good going down but relies on the hydraulic support when reversing so the idler doesn't kick out and cause slippage. Checking the oil in the idler line is important. With the 10k you have twice the torque since it has a 2 to 1 reduction to the spindle.
Always try to run the rpm as high as the surface speed will allow; just going from 100 rpm to 200 rpm improves the motor torque efficiency.
In our job shop days with similar material, we would run the hole diameter as large as possible to reduce the torque requirement.
We had some nasty titanium that we couldn't even drill the hole without melting the drill and we had a couple of hundred parts to drill. Lucky we found we could anneal the titanium, drill the holes then heat treat them again.
Hope this helps...
We all hope for a Treat not a Treatment!
