588,525 active members*
5,948 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal VMC 3016 I Need Help PLEASE!
Hybrid View
    Aug 2010
    I have a vmc 3016, it is a 1992 but was remanufactured in 2002.
    I am having issues with my Y axis. The circular interpolation is off.
    Basically what is happening when I go to cut a circle I have a flat spot on the top?
    I have replaced my couplers, checked the backlash, and adjusted my amplifier signal gains.
    I am trying to adjust my gibs, but I am stumped bryond this?
    Any help would be greatly appreciated.
    Jay
    Mar 2003
    900
    Jay--
    Start with verifying the level of the machine. Next adjust the gibbs and straaps in all three axis. Next verify the thrust bearing slop and ball nut to ball screw slop. Verify that your servo loop gain is adjusted for 595 because you have DC servos.
    If you still have the problem start checking the tachometer in the motors, the resolvers, the possibility of a weak motor or a weak amp.
    Since you have replaced the couplers, verify that the two sides of the couples are not bottomming out as they rotate.
    This is a lot of checking but this should help you find the issue.
    Neal
    Sep 2007
    11
    Jay
    You might have a backlash problem, since you check your backlash in static mode you can not see the real value, the next step is check the machine with a ball bar, this will monitor the dynamic backlash.
  1. Fadal 3016/Fanuc 18i question
    By fanucuser1 in forum Fadal
    Last Post: 06-09-2010, 01:44 PM
  2. Fadal VMC-3016 with 20 tool DATC
    By jonthebrit in forum Fadal
    Last Post: 04-15-2010, 01:36 PM
  3. Wiring a '96 Fadal 3016 to a RPC
    By FadalNewbie in forum Fadal
    Last Post: 09-25-2009, 11:21 PM
  4. tutor for fadal 3016 w/ 88 control
    By Runner4404spd in forum Employment Opportunity
    Last Post: 02-25-2009, 10:13 PM
  5. Reman Fadal 3016 Questions
    By RDTS in forum Fadal
    Last Post: 11-20-2008, 04:12 PM
