588,227 active members*
5,179 visitors online*
Results 1 to 5 of 5
    Apr 2013
    3
    Fagor 8055T Error 214.
    Hello. I have a problem with my lathe. It shows E.214 on the drives and next to them writes L1. I found that this error is short-circuit. Can you help me fix it? Thank you.
    Apr 2013
    3
    bump
    Dec 2011
    73
    Quote Originally Posted by soapcy View Post
    Ok, 3 digit error codes relate to the Fagor drive, not the CNC control. What model drive is? The error should be displayed on the segment display of the affected drive.
    Apr 2013
    3
    The drive's model is MCS-20L
    Input: 3 X 220 VAC / 50-60 Hz
    Weight: 3.8Kg
    CTRD-L: 05C, POT-L: 03C, OPR: 00A, VAR: 00A, SOFT: M203A21, MOT:02
    lo: 10 Amp
    lmax: 20 Amp
    Dec 2019
    Hello. I have a problem with my lathe. It shows E.214 on the drive axic x ,and I found that this error is in
    center board RF driver IGBT . Can you help me fix it? Thank you.
  1. Fagor 8055T
    By wht_brd in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-02-2014, 04:10 PM
  2. Help with my Fagor 8055T
    By Boxhead in forum DNC Problems and Solutions
    Last Post: 04-12-2012, 06:09 AM
  3. Programming G68 error 1049 ON FAGOR 8055T
    By claudiu220405 in forum Fagor Automation
    Last Post: 08-16-2011, 02:35 AM
  4. Help required Fagor 8055t
    By MAINTAINERS in forum Fagor Automation
    Last Post: 01-27-2009, 07:21 PM
  5. Fagor 8055t
    Last Post: 11-09-2006, 02:38 PM
