588,445 active members*
5,077 visitors online*
Results 1 to 4 of 4
    Sep 2006
    Fagor Radius Problem
    I am using an 8055 controller on a 3 axis mill and am having trouble undershooting or overshooting inside and outside radius cuts. It works fine with a feed rate @ 50 or below but anything over this and it cuts too much material or not enough material. Any suggestions?
    Sep 2004
    38
    Show example of the program.
    Jun 2006
    478
    Some controlers erroniosly cut radii at high feed rates try using cutter comp. to dial it in.
    Sep 2006
    Program Example
    G1 Z0
    G3 X-6.071 Y3.573 R.014
    X-6.057 Y3.5736 R.014
    X-6.071 Y3.5876 R.014
    X-6.085 Y3.5736 R.014
    G0 Z.5
