Re: False Limit switch Errors rear's it ugly Head!!!!!!!!
Years ago the old adage was to ensure only one end of a cable shield was connected to earth GND, the reason expounded for this was the possibility of causing a dreaded ground loop.
Now with the practice of equi-potential bonding, now grounding both ends of the shield is preferred, as outlined in the Siemens and Schneider PDF's.
Al.
Albert E.
