603,970 active members*
3,122 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > False limit switch trigger after replacing router mount
Results 1 to 5 of 5
    Jan 2013
    18
    I've been using my diy cnc router for about 7 years using a homemade wood router mount. I just today replaced with an aluminum mount and now am getting a limit switch trigger when cutting.
    Mar 2007
    2083
    Re: False limit switch trigger after replacing router mount
    without a photo or other details my first thoughts are
    either you have disturbed the limit switch or its wiring
    or with vacuum dust collection static discharges to the new metal mount are triggering the false limit signal
    John
    Jan 2013
    18
    Thanks John. Dust control is not hooked up yet but I believe it is router motor noise being transferred thru aluminum which mount I checked my denounce and was only set to 100 and changed it to 1000. It finished the cut last night so we’ll see. Thanks again.
    Quote Originally Posted by john-100 View Post
    John
    Jan 2005
    15362
    Quote Originally Posted by wmpinion View Post
    You have noise from the spindle before it was isolated from the wood mount, Try adding a Ground wire back to the Main power supply input Ground all Grounds should have a star point
    What type of spindle do you have and How is it wired ???
    In Mach3 General Config you can make an adjustment to the Debounce this will help but won't solve the problem
    Mactec54
    Jun 2012
    154
    Almost certainly ground loops and bad earthing practices. Read up on how to correctly ground all parts of the machine, especially the spindle motor and power supply.
    Check the ground pin at the spindle is actually connected to something. Often chinese spindles have a forth pin but it is not connected. Connect to the body of the cable socket body.
  1. Phantom limit switch trigger
    By techteacher15 in forum CNC Machine Related Electronics
    Last Post: 04-26-2016, 11:29 PM
  2. False Limit switch Errors rear's it ugly Head!!!!!!!!
    By Barefootboy4 in forum DIY CNC Router Table Machines
    Last Post: 09-06-2015, 06:06 PM
  3. Limit/Home Switch False Triggers
    By cyberkeith in forum DIY CNC Router Table Machines
    Last Post: 03-13-2015, 02:18 AM
  4. syil xp5 trigger limit switch
    By Vik in forum Syil Products
    Last Post: 10-29-2010, 07:05 AM
  5. Limit swtich false trigger
    By HakBot in forum Benchtop Machines
    Last Post: 10-04-2008, 07:01 AM
