hi i need hep
fanuc OI TC alarm 1420
hi i need hep
This sounds like a MTB alarm. What make / model of machine is it?
the machine is HWACHEON HI-TECH200B
alarm 1420 tool presetter position alarme
thanks
I don't have any documentation on this machine, but I would guess that the alarm is being generated by the tool presetter "up" switch. You should be able to locate the input for that switch (Xnnnn.n) on the electrical drawings and check the diagnostics to see if the switch makes when the presetter is up.
On a Doosan P240, the input is X0005.7 for Q-Setter arm UP and X0004.6 for arm down. You can go to SYSTEM, [PMC], [PMC DGN], [STATUS] then key in X0005.7 and press [SEARCH]. Operate the presetter and watch the bit to see if it changes 0 to 1 when the arem goes up. If not, the switch or arm may need adjustment.
thanks
when i push button indexagage of Tourette the alarm 1420 coming
Are you trying to index the turret with the tool presetter arm in the down position? A lot of MTBs disable turret index with arm down so the turret can not index into the arm. This usually generates an alarm if you try to index the turret with the arm down.
hi all
iam teste the input clump unclump turete X5.6 and X5.7 in SYSTEM, [PMC], [PMC DGN], [STATUS] is ok .
iam backup fils sram to the cnc but the alarm is Current
hi all
i thank you to mach
dhe alarm (1420 tool presetter position )in machine HWACHEON HI-TECH200B
is only dhe cover touchprobe is opened .
if any man want a document fanuc OI Mmat ,send me a email in :[email protected]
or:[email protected]
i want a Fanuc 6MB manual pleas send it mi in my email. thanks
thanks too much.
hi all
i need a document manual maintenance fanuc OT OM send it me by email:[email protected]
thaks
