587,303 active members*
3,358 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 0i Mate-MB battery/batteries
Page 1 of 2 12
Results 1 to 20 of 25
    May 2008
    57
    I have a Sharp SV2412 with the Fanuc 0i Mate-MB control. I know where the backup battery is on the control unit (A98L-0031-0012). Are there any other batteries I should change? I'm new to Fanuc and don't want to lose any data or parameters.
    Thanks,
    RBC Metalwork
    Honolulu, Hawaii
    Feb 2006
    1792
    6V APC battery, somewhere in your electrical cabinet.
    May 2009
    181
    just change them with the power on..
    Attached Files Attached Files
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
    Feb 2006
    1792
    Quote Originally Posted by fanucman View Post
    Should EMERGENCY be applied, or it does not matter?
    May 2009
    181
    doesnt matter...
    May 2008
    57
    I still can't find the 6v battery. Here are pictures of the drive section if that helps. I can look into the drive from vents on the bottom but I don't see any battery.
    Trace the CXA2A cable this will lead you to the optional external battery pack
    or CX5X to the Fanuc ABS Battery
    The Beta i drives generaly have a battery cover attached to the two holes you can see in your photo
    so it probably has the external grey box on the outside of the machine with FANUC written on it.
    Attached Thumbnails Attached Thumbnails Batteries 002.jpg   Batteries 025.jpg   Batteries 029.jpg
    May 2008
    57
    Nothing is connected to CX5X except for a small brown plastic part. It's only function is to keep the two pins from shorting to each other. I don't have a CXA2A. I do have a CXA2C though. CXA2C has blue wires running into the cable trays.
    Randy
    SV-2412, 0i Mate-MB
    Is your machine an absolute encoder type or incremental type
    post the values in parameter 1815
    your machine might not have the 6V lithium ABS battery backup only the 3V Lithium Parameter/Memory backup
    May 2009
    181
    check 1815 bit 5 for apc...
    also do you need to do a zero return before running machine...
    May 2008
    57
    Parameter 1815 shows all zeros.
    Yes, I must home X, Y and Z at every power-up.
    Randy
    SV-2412, 0i Mate-MB
    May 2009
    181
    Quote Originally Posted by rbcmetalwork View Post
    ok so there is no battery.. these are incremental encoders..
    Oct 2009
    297
    Does it matter?
    Quote Originally Posted by sinha_nsit View Post
    Do not change batteries while the machine is running. It will cause your program to stop.
    Jun 2005
    232
    I have the same machine and control Sharp 2412 fanuc oi mate mb .
    I have batteries for my absolute enocoders but I have to home my machine
    at start up . Why not one or the other ?
    Tim
    Oct 2009
    297
    Quote Originally Posted by timlkallam View Post
    Sometimes the drives are sold with the batteries although your machine might not have absolute encoders. You should check parameters 1815 bit 4 and 5 to see if the machine really has absolute encoders.
  17. #17
    Jun 2005
    232
    It has absolute encoders for sure. I had to take the z axis motor off so the machine would fit under the garage door. But it back on and homed the machine z was in the wrong place would not home.
    It took the service guy a day to figure it out. He did the Z zero home .
    I have to home the machine but it has absolute encoders .All so I have changed the 6 volt batteries twice sence I had the machine when I get the alarm.
    So why do I have to home a machine with absolute encoders?
    Service guy did this
    Zero return Z
    If machine Zero return works change 1320 back to 2000
    If it does not work change parameter 1850 to 1000 and try again if necessary change in 1000 increments up 5000.
    If this does not work change to -1000 in one thousand increments.
    If parameter 1850 is changed, the tool change position must be set using the following procedure:
    With head at home position set machine position to 0 Use the MPG to move the head down approximately 4.00”
    Unplug the air supply and manually move the carousel in to check the alignment.
    Adjust the head using the MPG so the fingers align with the tool.
    Multiply the machine position X 25400, insert this number in parameter 1241.
    NOTE: After each change of parameter 1850 turn off the machine and re-start.
    Machine with Pulse coder Change parameter 1815 bit 4 to 0 (APZ)
    Line up index marks (Located on the side of the head)
    Turn off power
    Turn on power and change parameter 1815 bit 4 back to 1
    Turn off power
    Turn on power. (Zero return should work)
    Tim
  18. #18
    Sounds like the Z-Axis 'jumped a grid' this happens when the Z-Axis Home position is too close to the Encoder Marker Pulse.
    Also This only really happens if the Z-Axis motor was not refitted in the same position. The service engineer should have made sure to mark the couplings and the ball screw before dis-assembly.
    I would reset your home position with a similar but more precise procedure.
    Please post your parameter 1815 this will clear up all confusion.
    If you have changed the ABS batteries before you should know where to find them !
  19. #19
    May 2008
    57
    It was I, rbcmetalwork, who could not find the battery, not timlkallam.
    Randy
    SV-2412, 0i Mate-MB
  20. #20
    Oct 2009
    297
    Check parameter 1815
    Zero return Z
    Turn off power
    Turn off power
    You should check parameter 1815.
    Also check parameter 1005 bit 0 = A command is issued in automatic operation before a return to reference position has been performed since the power was turned on, an alarm is generated (0) / alarm is not generated (1)
Page 1 of 2 12
  1. Fanuc 10M Parameters...no batteries
    By spank in forum Fanuc
    Last Post: 03-29-2011, 08:56 AM
  2. Battery Replacement on Fanuc 0iMB
    By syamin in forum Controller & Computer Solutions
    Last Post: 10-12-2009, 06:10 PM
  3. Fanuc amplifier 6v battery / Mach3
    By fomaz in forum Fanuc
    Last Post: 09-30-2009, 04:59 AM
  4. Strang Fanuc battery question
    By timlkallam in forum Fanuc
    Last Post: 12-06-2007, 12:52 AM
  5. Replies: 2
    Last Post: 07-17-2007, 04:19 PM
