587,789 active members*
5,400 visitors online*
    Nov 2008
    Fanuc 0t servo alarms
    I'd appreciate some help/advice.
    I have a Fanuc 0T (circa 1989) with what I believe are S series ac servos.
    It is coming up with alarm 400 (overload).
    I have read that the 400 alarm can be caused by the motor overheating. Is there therefore a thermal switch/thermistor in these motors? If so does anyone know where they may connect into the control/servo? (note: the motors are not getting hot and the error is there at power-up, there is some damage to the cable chain running to the x axis therefore a possible broken cable)
    I have no electrical drawings for this machine, and only an operator manual for the 0T. There are some connections along the bottom of the servo card (adjacent to the incoming power and motor connections) labeled something like 100B or IO0B - is this the thermistor connection?
    Many thanks.
    Dec 2003
    24220
    If you take the red cap off the rear of the motor, you will see the encoder cable and also a pair of individual wires, usually white or black that come out of the motor winding, this is the thermal sensor.
    These go to the canon connector and should measure closed circuit.
    The termination for these are usually labeled OH1 OH2 etc.
    Depending on the drive, these usually end up in the Honda connector on the bottom of the drive.
    100A 100B are usually a 100vac input.
    What is the model of drive?
    Al.
    Albert E.
    Nov 2008
    Thanks for your reply Al,
    Seemed to have got it fixed today...it was a cable problem as suspected.
    Cheers,
    James
  1. Fanuc 0t-C 409, 414, 424 alarms
    By acerocket in forum Fanuc
    Last Post: 12-08-2015, 06:56 AM
  2. Fanuc Servo Alarms 401, 414, 424
    By sushrut in forum Fanuc
    Last Post: 10-20-2013, 09:31 PM
  3. ALARMS 600 AND 607 ON FANUC 6M
    By POSADAS in forum Fanuc
    Last Post: 09-04-2008, 07:37 PM
  4. Fanuc 0TC with 409 AL-31 alarms
    By bob1112 in forum Fanuc
    Last Post: 07-07-2007, 12:04 AM
  5. Fanuc 6MB 401 and 410 alarms
    By john braks in forum Fanuc
    Last Post: 02-24-2006, 07:45 AM
