587,354 active members*
3,155 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC 10M OKK PCV40 communcation eroor
    May 2012
    32
    Hello,
    I had my machine running today, did a spindle orient and warm up, i went to do a Z home sequence and the control froze.Now i cant get the control to turn on, yet the screen does.
    My master board LED screen shows an "A" which i believe is a communication error ? I'm not sure exactly which one though ???
    Re: FANUC 10M OKK PCV40 communcation eroor
    Display: A.
    Description: MDI Connection Failure.
    Repair: Check fiber optic between cable connection control and MDI/CRT unit.
    We have several times this alarm when have problem with power supplies for equipment on second side of optical cable ( p.s. for I/O unit or p.s. for crt-mdi unit)
    May 2012
    32
    Thanks nsdjole,
    We are going to look at this today. I will confirm with you on this.
  1. Replies: 0
    Last Post: 01-28-2014, 04:41 AM
  2. Replies: 7
    Last Post: 11-17-2013, 01:46 AM
  3. PCV40 5th Axis
    By Jones'r in forum OKK
    Last Post: 08-18-2012, 12:40 AM
  4. OKK PCV40 5th axis
    Last Post: 05-29-2012, 05:51 PM
  5. Replies: 5
    Last Post: 03-09-2011, 04:11 PM
