603,350 active members*
4,821 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 10m short circuit limit switch
Results 1 to 8 of 8
    Mar 2008
    150
    Did a big mistake and got a short circuit with the screwdriver when i should tighten the terminals on X-axis limit switch...
    Have had problems with that the control sometimes does a limit switch alarm when i do fast movement to Y-home. The alarm just stops the control and as soon the alarm comes - it dissapears and i can start the program again but it's very irritating...
    Have replaced the wires to the Y-limit switch and checked the switch / terminals and therefore i now was on the X-switch.
    However, now the control doesn't work at all and i have parts that should be machined....
    The control seems to got into "emergency stop" mode and i couldn't do anything... Have checked every fuse i could find in the cabinet but can't find any bad.
    The crt's Operator Message says:
    Ex 06 Emergency Stop
    Ex 08 Spindle Servo Alarm
    Ex 11 2ND Limit Switch is Working
    Ex 13 Spindle Oil Air Alarm
    On the masterboard there is code "1", that says normal operation.
    Have tried with: "disconnect" check soft OT at power on - in IPL mode, but that didn't made any difference.
    What should i do to get rid of the alarms? Could something got broken by the short circuit?
    Please help....
    Kitamura Mycenter 1 -83 with Fanuc 3M-C and Mycenter 1B -85 with 10M control.
    Yes, they are old..... but i still like them!
    Dec 2003
    24260
    Have you checked the small fuses on any of the I/O boards, I/O type boards vary depending on the specs of the system you have?
    Al.
    Albert E.
    Mar 2008
    150
    Thanks Al for your quick reply! No, i dont think that i found any "small" fuses..? Only some green fuses (not that small i think) and some bigger black fuses. Do you have any picture or link to the small fuses you mean?
    Is it the I/O board that "controls" the limit switches?
    Dec 2003
    24260
    There are quite a few different possible configurations for the 10/11/12 etc, some remotor I/O boards are fibre optic fed, others hard wired, but most have the small green fuses on them. Usually it is these that go if there is a short on any of the I/O.
    Al.
    Albert E.
    Mar 2008
    150
    I'm not near my cnc at this time but i have documented that the I/O board is:
    DI/O Board: A16B-1210-0322 A
    When i google this i can see that there seems to be one green fuse at that board and i know that i didn't checked that because it's in a very bad place...
    I will check that as soon as possible... could it be that fuse that is given me these alarms, and put the control i emergency stop? Could it otherwise perhaps be the power supply?
    Thanks!
    Mar 2008
    150
    Well, it sure was the fuse on the I/O board! Ordered some new fuses yesterday after i checked it on the morning and got it today. Tested it tonight and bingo, it works again! :banana:
    Thank you very much Al the Man for your help that pointed me to the right place.
    /Swemill
    Jan 2006
    121
    Congratulations Swemill and nice job Al_The_Man
    Although I have been a little more order on my Fanuc who is in office.
    Right now it works LSK / output again on the screen. I see that the port is trying to send.
    So with a little luck it may just be soldering job now then ..... again
    You can see my discussion in same three under Fanuc/Ladder RS232
    /DW
    Quote Originally Posted by Swemill View Post
    /Swemill
    I currently have the same issue. I don’t see any blown fuses though, unless there is one in a location I don’t see.
    Which fuse was it of yours?
  1. Question about tying two grounds together for an opto limit switch circuit.
    By Hogstrom in forum CNC Machine Related Electronics
    Last Post: 04-25-2013, 12:46 AM
  2. REGULATOR SHORT CIRCUIT
    By Arjuna in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 04-05-2013, 10:13 AM
  3. Fanuc 10M - 2nd limit switch problem!
    By Swemill in forum Fanuc
    Last Post: 01-06-2012, 08:51 PM
  4. Cnc lathe override limit switch problem fanuc t15
    By tomislav_kozul in forum Fanuc
    Last Post: 12-31-2011, 10:59 PM
  5. EX 02 Safety Limit Switch Engaged FANUC 11 SERIES ON NTC MACHINE
    By Epik in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-27-2005, 11:20 PM
