Hey guys.
I have a Fanuc 10T 1985 Hitec-turn 25 lathe. The machine sucks down way oil like crazy! Every day The machine goes through an entire fill up of way oil. Most machines I have been on will go a week or 2 without needing to fill up. Can I slow down the interval of the motor pumping way oil? Is there a parameter I can change or do I have to put some type of a switch and manually control the lube motor?
Thanx for your help.
Dave
