587,836 active members*
4,944 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 10t Lathe. Kchp wires got shorted, now getting sv013 alarms!!!!
Results 1 to 7 of 7
    Jan 2009
    245
    Ok, so I went to hook up my Chip Conveyor to the HT20 Hitachi lathe with the fanuc 10t control. I got the three phase wiring hooked up to the internal relays on the control box of the conv. up. But then there is a Blue and Orange wire that went to some sort of contact, but when testing what these wires do I accedently touched them together, and got a small spark. After seeing where these wires go, I found out that they go to a connector on a board called Kchp. Anyways now I am getting SV013 alarms for X and Z axis. I have tried reseting the breakers on the servo drives, but no luck on correcting the alarm. Where Else Can I look?
    Jan 2009
    245
    Ok after further investigation, I found that the distribution board had some burned traces, see photos. So I had a spare board and installed it, with the conveyer totally disconected, and am still getting the same alarms!! WHen I hit the reset button, the Prdy led on the servo drives lights up for a second then turns off, and has the same alarm. Where shall I look next?
    Attached Thumbnails Attached Thumbnails IMAG0101 (Medium).jpg   IMAG0102 (Medium).jpg   IMAG0103 (Medium).jpg
    Jan 2009
    245
    By the way, NO voltage across terminals 3 and 4 on T1 of the drives. Also no other LED's displaying alarms on the Drives. Im stuck guys.
    Jan 2009
    245
    I am getting 240vac across each of the three leftward terminals on the Drives. A, 1, 2.
    Dec 2003
    24220
    I will dig the HT20 manual out and see what I can see!
    Al.
    Albert E.
    Jan 2009
    245
    Any ideas?
    Dec 2003
    24220
    Can't seem to find that Dis board in the prints?
    Did you repair the trace and checked all fuses?
    Al.
    Albert E.
  1. Fanuc 21-tb alarms
    By Hlynur in forum Fanuc
    Last Post: 12-06-2012, 04:44 AM
  2. Shorted motor?
    By richlandrick in forum Automation Technology Products
    Last Post: 04-17-2011, 05:17 PM
  3. SV013 Alarm Fanuc 11M
    By kalawa in forum Fanuc
    Last Post: 12-02-2009, 11:46 AM
  4. Fanuc 400 alarms and other
    By alphatad in forum Fanuc
    Last Post: 02-04-2008, 03:32 PM
  5. Fanuc 6MB 401 and 410 alarms
    By john braks in forum Fanuc
    Last Post: 02-24-2006, 07:45 AM
