I have several CNC machines that all communicate to the same PC through a switch box. All machines but one are communicating fine in both reading and punching programs. That tells me nothing is wrong on the PC side.
I have tested the "broken" machine in one of the ports on the swich that work for other machines, so also this has been excluded as possible point of error. The cable from the "broken" machine has also been tested with a working machine and works fine.
Left is the machine itself! It is a Fanuc 10T Model A controller on a Citizen Cincom E32IIIY. In the controller there are parameters for 3 devices but I know the machine only has one. I'm not sure which one so I have set identical parameters for all 3 devices. 7/even/2/XonXoff and I have tested at both 1200 and 2400 baudrate. TVCHECK=0, PUNCH CODE=0, INPUT UNIT=0.
Is there something I'm missing? Or does this all tell me that my rs232 interface is simply broken. Does anyone have suggestions for more things to test?
In advance thank you for replying!
Regards,
Lene Madsen
