588,166 active members*
4,786 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC 10T SO27 Z DGTL SERVO ERROR
    Jan 2009
    7
    how to solve the S027 dgtl servo error on a mori seiki SL-25 i had this error after resetting the nc parameter ?????
    Jan 2009
    117
    I assume that the Mori is using FS-10T with Digital servo interface.
    The alarm is very likely SV 027 Z DGTL.
    If you have reset the parameters then you should also have had SV 027 for the X-axis. I don't understand why the X-axis is ok but not the Z-axis.
    All I can think of is some finger trouble when you re-entered the parameters by hand. If you have the parameter list, I suggest that you re-check the Z parameters thoroughly starting from 1800 to 1899.
    You should especially check the following parameters:
    1806
    1865
    1866
    1869
    1879
    1891
    Better still if you have a parameter backup on your PC. Just read in the parameters via the RS-232 port after the option parameters were set in the IPL screen.
    Jan 2009
    7
    I ll try it right now , hope this will solve the problem. thanks for help
  1. FANUC 6T ERROR 401 SERVO
    By cjchands in forum Fanuc
    Last Post: 04-22-2009, 05:09 PM
  2. Replies: 7
    Last Post: 10-26-2008, 08:51 PM
  3. Z AXIS SERVO ERROR, NEED HELP
    By bgmnn in forum HURCO
    Last Post: 12-11-2007, 07:09 AM
  4. X servo error on tm-1...
    By superrat in forum Haas Mills
    Last Post: 04-16-2007, 05:14 PM
  5. servo error
    By JimS in forum CNC Machine Related Electronics
    Last Post: 08-05-2003, 03:23 AM
