587,189 active members*
3,271 visitors online*
Results 1 to 5 of 5
    Nov 2009
    75
    Fanuc 10T - SV 011 LSI Overflow
    Hello,
    We have a moriseiki sl-2 ,fanuc 10t controller, dc velocity servo unit
    Does anyone meet this error beforeX Axis : SV 011 LSI overflow error while machine ready and x axis move rapidly then stop with this alarm (there is no alarm on servo unit)
    I checked all forum also 10t maintenance manual, i did and recheck what they said and check all parameter 1816. 1820 . 1825-----1830 and others servo spec,
    But there is no wrong parameter or anything, i change servo velocity unit with another working one, but problem same , i swapped x and z axis servo motor include pulsecoder , problem still same
    I find 40 Pin ICs for LSI (on masterboard) and changed but problem still same, checked and clean carbon brush but their condition is good
    Only one thing; servo velocity unit is ready when change motor cable or CV1 to CV2 on masterboard , or CF1 to CF2 on masterboard,
    only one configuration as above effect it to ready condition of servo unit,
    If we try to move any axis manually 2 axis move rapidly and stop then appears excess error , if no action for move machine is waiting for ready condition
    Which kind of problem could be , is this from masterboard? ,
    Anyone help or any idea
    Regards
    Jan 2013
    37
    Re: Fanuc 10T - SV 011 LSI Overflow
    Had this happen twice on 2 different machines. Replaced both power and feedback cables for axis and problem solved. Can't guarantee this is your problem but it was mine. If its jumping around I would say its your feedback cable.
    Feb 2009
    6028
    Sounds like a broken tach wire.
    Nov 2009
    75
    Quote Originally Posted by underthetire View Post
    Gtmondock, underthetire
    Thank you so much, After check it, i Will post result
    Nov 2009
    75
    Quote Originally Posted by freemanxxx View Post
    Hello again
    For this problem we checked all cable but their condition is good
    So last thing is masterboard because pulsecoder and velocity unit connect to CV1-CV2/CF1, CF2
    Is this problem happen from masterboard ?
    Spec NO is A16B-1010-0040
  1. Fanuc 10M Buffer Overflow
    By nastek in forum Fanuc
    Last Post: 06-01-2017, 11:02 PM
  2. Y dac overflow
    By fullbore in forum Bridgeport / Hardinge Mills
    Last Post: 06-25-2011, 01:48 AM
  3. way oil overflow?
    By Brendan in forum Haas Mills
    Last Post: 01-21-2011, 05:11 AM
  4. FANUC 15M SR844 BUFFER OVERFLOW (3)
    By andre324 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-04-2010, 11:06 PM
  5. Fanuc 11m overflow
    By Nandop in forum Fanuc
    Last Post: 03-05-2007, 08:11 PM
