Hello everyone,
I have this problem, when I program G02 or G03, well in this particula case is a G03 the movement is odd. Let me explain
G00 X14.0 Z.26
G1 Z.16 F.01
X10.1894
G03 X4.5239 Z.7336 I-.0009 K7.2767
G1X4.6653 Z.8043
G00 etc.
Well, at the start of the G03 the tool instead of continuing the move, starts a radius move that goes inside the part (making the radius) and at the end finishes ok but after making a big curve inside the part.
I have tried everything I can think of, but I believe that there is a parameter that is causing it. If it is a PC parameters then I have no way of finding out as I only have the NC parameters description.
The machine is a Leblond Makino, Baron 25 fanuc 10T
Any help will be aprecciated
jolulank
