603,385 active members*
2,663 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 11m Ram Parity Error / Adress Error
    Sep 2022
    4
    Hi, I know three was many threads about it, but i think my problem is another.
    Matsura MC600h. When I turn the machine on, she's working 30s to 1 minute and then display Ram Parity Error. When I turn she again is displayed Adress Error or IPL menu.
    Should I clear memory or the problem is in voltage 24DC? What signals should been on ALC & ALD connectors?
    Sorry for my English.
    Best regards
    Apr 2009
    1401
    Re: Fanuc 11m Ram Parity Error / Adress Error
    Make sure you have a complete back first.
    Check all voltages when the problem occurs: 5V. +-15V, 24V
    If you have a ROM/RAM board, it is the likely culprit, but you can't rule out the main board.
    Sep 2022
    4
    Quote Originally Posted by memoryman View Post
    Thanks for your answer. Voltages on Master PCB are correct,but I don't know what voltages should be on Alc & Ald Pins on I/O Board. In mine machine they have 22Volts but I don't know if it has any effect. I have backup of the parameters. I'm a little scared clear memory ????
  1. RAM ERROR PARITY FANUC
    By juliocnc in forum Mexican Club House
    Last Post: 03-10-2021, 08:51 PM
  2. fanuc 15TF ram parity error
    By rai in forum Fanuc
    Last Post: 12-30-2020, 06:53 PM
  3. Fanuc 10 M Ram parity error
    By cncmori in forum Fanuc
    Last Post: 02-17-2020, 01:20 AM
  4. RAM Parity Error in Fanuc 11M
    By starweldengg in forum Fanuc
    Last Post: 04-30-2015, 10:28 PM
  5. Replies: 0
    Last Post: 11-26-2012, 09:03 PM
