603,979 active members*
1,336 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 11M...Is there a way to get Tool change Parameter if losing one?
Results 1 to 4 of 4
    Oct 2006
    142
    I just recently got this SHODA NCB-193C CNC 3 axis with 16 ATC.
    X/Y/Z and spindles work ok.
    But nothing in Parameter for TOOL CHANGE.
    our tech service said...without parameter...there is no way to get it working.
    We do not have any manuals, but just testing each TOOL change function...they work individually.
    Any advice?
    Jun 2008
    1511
    What happens when you try to do a tool change by programming a T()M6? There may be a PMC parameter that is set for the tool in the spindle and the tool change pocket but not always. Do you have a tool change macro program? If so can you post it?
    Stevo
    Oct 2006
    142
    Too parameter page is all
    0 00000000000000000
    Jun 2008
    1511
    Which parameter page is all 0's. PMC, NC, timers, counters etc. There are a lot of parameters in the machine so you have to be a bit more specific. I ass u me that it’s not the NC because your machine is functioning. It is probably your PMC parameters but you have to keep in mind a lot of these are going to be blank. Without the MTB manual this could be a bit of a task.
    So again what does your machine do when you try to program a tool change via M6?? Do you have a tool change macro?? It would probably be in the 9000 program number range.
    Stevo
  1. Fanuc 18i optional parameter change
    By jojojoo in forum Fanuc
    Last Post: 02-27-2024, 06:52 PM
  2. Please help me, tool change Fanuc OMB
    By baow in forum Fanuc
    Last Post: 08-19-2009, 12:25 PM
  3. losing Z after tool change
    By windsors in forum Mastercam
    Last Post: 09-29-2008, 01:28 AM
  4. Tool Change Parameter
    By Jason812 in forum Fanuc
    Last Post: 11-21-2007, 02:29 AM
  5. Tool change on Fanuc OT
    By steedspeed in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-11-2006, 09:37 PM
