588,228 active members*
4,622 visitors online*
    Jun 2006
    8
    Fanuc 11TT Axis Drive
    Hi all, I'm a new poster although I've been lurking for some time. Sorry for the lengthy post.
    I have a Miyano ANC-35 with Fanuc 11TT. I receive the following alarms:
    SV003 Z1 Abnormal Current
    SV004 Z1 Excess Voltage
    SV006 Z1 Velocity Unit Power Too Low
    (SV006 always follows shortly after the others, perhaps due to the unit shutting down?)
    I've also noted the following alarm LEDs on the drive unit:
    HC
    OVC
    TG
    Following advice I found on this forum I swapped out the X & Z cables between the two drives to try and isolate the problem. The error stayed with the drive unit which I believe indicates that my drive is at fault and my motors are OK.
    My questions: Is anyone familiar enough with this system and drive unit to give me any hints as to how I can diagnose and possibly repair it? If not, do I replace the top board or could the problem be elsewhere in the drive unit?
    Axis drive top board p/n:
    A20B-1000-0560/10E
    AC servos (red caps).
    I'm happy to provide any other info necessary.
    Thanks,
    James
    Jul 2011
    need help!
    do you have any operation manual, part list and maintance manual for miyano anc-35 tc-1?
    I need them. please replay me.
    thanks,
  1. Looking for a Drive for a Fanuc motor
    By 69owb in forum Servo Motors / Drives
    Last Post: 03-30-2007, 12:40 AM
  2. Fanuc spindle drive
    By mrwhittle in forum Fanuc
    Last Post: 03-29-2007, 11:28 PM
  3. Use of G10 L50 for 11TT fanuc series
    By marrieche in forum G-Code Programing
    Last Post: 02-19-2007, 08:19 AM
  4. Fanuc axis drive control PCB- S Series
    By M.RISHIKESH in forum Fanuc
    Last Post: 12-04-2006, 05:25 PM
  5. fanuc axis drive problem
    By turbo bob in forum Fanuc
    Last Post: 10-30-2006, 11:10 PM
