ALLO THE FANUC 15 M GIVE MY ALARM ( SR844 BUFFER OVERFLOW (3)
I SEND FILE FROM CNC TO PC OK WORK GOOD ( SOTFWARE PREDATOR DNC)
I TRY SEND FILE PC TO CNC ( ALARM) .......
HELP,,,,,,
ANDRE
HELP,,,,,,
ANDRE
Make sure you have S/W handshake enabled (XON/XOFF).
You could also have a hardware problem with the port.
Al.
Albert E.
Andre,
Click Start - Control Panel - System - Hardware - Device Manager - expand (click on the [+] to the left of Ports (COM & LPT) - right-click on the port you are using - Properties - Port Settings - Advanced - move both sliders for send and receivce FIFO buffers all the way to the left then uncheck "Use FIFO buffers". OK all the way out and restart your computer.
Try to send again. If this doesn't work you may have to add a character or line delay to your Predator Send command.
