587,784 active members*
2,496 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 15TF Alarms OT007 & OT008 (HARD)
Results 1 to 5 of 5
    Feb 2006
    213
    Smile Fanuc 15TF Alarms OT007 & OT008 (HARD)
    I have a Takisawa TC-2 equipped with Fanuc 15TF and I am getting following alarms
    OT007 X+ OT(Hard)
    OT008 X- OT(Hard)
    OT007 Z+ OT(Hard)
    OT008 Z- OT (Hard)
    I went thru Fanuc 15TF maintenance manual but did't find any help as G flag address are different. Also I checked the ot limit switches in machine but OT limit switches are wired in series.
    Even parameter 5201 was not found in cnc system to disable OT limit switches. as after parameter # 5200 then #5210
    Somebody help me & provide me the Connection manual Hardware suitable for Fanuc 15TF.
    Dec 2003
    24220
    Usually all OT at once are due to fuse or DC power failure somewhere to the OT SW's.
    These are active low, so without power they all show activated.
    I should have the manual, if you PM me an email add.
    Al.
    Albert E.
    Jul 2013
    12
    Hi Al, I have the same problem as Rai, ot007 and ot008 overtravel alarms in my 15a. I know this post is from a while back but do you think you could also send me a connection diagram if these limit swith connections?
    thanks,
    Brandon
    [email protected]
    Apr 2009
    1379
    Brandon, interesting that your email address is plccenter.com. I had conversations with their management about setting up a cnc testing facility. Don't they have manuals?
    Jul 2013
    12
    Yeah we have a lot of good manuals on these machines. I just havent been able to find a connection diagram that shows where these physical overtravel switches connect to. Any Ideas?
  1. ALARM OT007 +OVERTRAVEL HARD
    By KHOATRANNGOC in forum Toyoda
    Last Post: 09-23-2020, 01:11 PM
  2. Replies: 5
    Last Post: 10-12-2013, 02:23 AM
  3. Fanuc 5S servo tuning on Fanuc 15TF
    By rai in forum Fanuc
    Last Post: 02-05-2012, 11:38 PM
  4. Danichi B45 Fanuc 10T Error OT007
    By birdog1952 in forum Fanuc
    Last Post: 05-20-2008, 08:42 PM
  5. DNC to FANUC 15TF
    By bmlw in forum Fanuc
    Last Post: 01-07-2008, 08:23 PM
