587,143 active members*
4,162 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 16i 160i RS-232 Setup and missing parameters
Results 1 to 10 of 10
    Jan 2016
    4
    I have an Amada Laser with a Fanuc 160i controller that I am attempting to connect with FabriTalk to. However going through the parameter setup I do not see the parameters for setting up IO CHANNLE 0 or 1 0101, 0102, 0103 when in PWE mode. Am I missing something, They were visible several days ago. The only parameter change has been setting from Tape type 3 to RS-232 Type 4.
    An help or thoughts is much appreciated. Jeff
    Jun 2004
    511
    Re: Fanuc 16i 160i RS-232 Setup and missing parameters
    parameters for setting up IO CHANNEL 0 is normally on the Handy page, hit the offset key multiple times.
    Jan 2016
    4
    Is this a different screen that shows paramtet 0000 through 0100. It then jumps from 0100 to 0300.
    Jun 2004
    511
    I have a couple 160i controllers on Milling machines, maybe lasers are set up different. Can you post a picture?
    Jan 2016
    4
    I got it . It was actually on the System page. You went to the Handy and then hit system. Thanks for the help.
    Quote Originally Posted by Jfehr View Post
    I have (2) Amada lasers and I am not able to get them to work with rs232 what software and cabling are you using?
    Mar 2009
    101
    Quote Originally Posted by wallman200 View Post
    I use 9pin - 25pin Null Modem cable with a basic communication software. We sell a basic software if you cant find a free download.
    Exec Memory Software/Multiple Control (API A8665) - Mounts & Retrofits | Alternative Parts Inc.
    Quote Originally Posted by AMADAJOE View Post
    Thank you sir, I am currently working on the communication issues. I may follow up with you on the software.
    Apr 2009
    1379
    Why use a serial connection on an i-control? You can use the pc-card (next to the monitor) instead.
    Thank you..... I totally forgot it was there. Set up controler and we are loading programs again.:banana:.... Thank you for your help.
  1. Fanuc 160i .Cannot boot
    By Jeff_B in forum Fanuc
    Last Post: 05-19-2013, 11:48 AM
  2. Please help! Adding axis to Fanuc 160i
    By ausman12 in forum Fanuc
    Last Post: 01-28-2012, 07:41 AM
  3. How to Upgrade to Win XP on Fanuc 160i
    By sigit in forum Fanuc
    Last Post: 01-22-2010, 09:31 AM
  4. Replies: 2
    Last Post: 02-03-2008, 03:45 PM
  5. Replies: 4
    Last Post: 03-10-2006, 07:37 PM
