I am looking for help on adjusting the travel limits for a Fanuc 18-MB controller. I don't have a manual for the parameters which I would think would help me adjust the limits. The manual is B-62450E/02. Thanks Jon.
I am assuming you want the soft over travel limits. Parameter 1320 Plus limit and 1321 Minus limit. These values are based off of the Machine position on the position page. You type in the distance you want the machine to stop at and display the over travel alarm. Example, For X -325.500 you would type in -325500 in parameter 1321 for the X axis, the decimal point is left out of the parameter but the minus has to in there. Hope this helps
