603,912 active members*
4,042 visitors online*
Results 1 to 19 of 19
    Sep 2006
    9
    Fanuc 18i custom macro B
    I am adding Renishaw probing to two Makino A71's with Fanuc 18i control. For probing it says that Custom Macro B and high speed skip are needed. Do I need software for this or is this a parameter change. please help.
    Feb 2006
    340
    The macro B is just a software option. High speed skip is a hardware/software option. I don not know about the A71's, but a FEW manufacturers put the hardware on all the machines regardless of the options ordered.
    Bottom line, I'm pretty sure you need to talk to your dealer to get it to work.
    At the very least you need 1 machine with it installed and working. (if you have more than one)
    Sep 2006
    9
    cancel
    Sep 2006
    9
    Fanuc 18i macro B
    So I take it that this option is not something that can be turned on with parameters as is the case for older Fanuc controls
    Mar 2005
    988
    The A71 is not that "old" and neither is your control. However, on a Makino, its possible it may already be installed. Macro B should already be active with the Pro3 control and for the High Speed skip, you may already have the card installed. It's just a matter of someone coming in and making it active to the control. I know for sure the low speed skip should be running. Do you have the tool eye option on the machine? (That's the tool length measure unit). If so, you already have a skip card installed.
    It's just a part..... cutter still goes round and round....
    Nov 2005
    274
    Quote Originally Posted by djmcdaris View Post
    High Speed Skip 9936.4
    Custom Macro B 9933.7
    Additinal Varibles 9937.4
    I am pretty sure you can get the Macro B abd theb daitinal Varibles But the Skip function might need a hardware upgrade.
    Just make sure you have a back up of all your machine system parrameters befroe you start messing with the option parrameters
    Bluesman
    Nov 2006
    51
    Bluesman,
    is additional variables 9937.4 the same on a 18M model C control?
    Feb 2006
    340
    Quote Originally Posted by hydrospin01 View Post
    Bluesman,
    Yes it should be the same for all 18 and 21 controls. In general these share all the option parameters. Lathe and mill specific options being the exception I believe.
    Sep 2006
    9
    Once I change these parameters how can I tell if they are activated. Is there a G code
    Nov 2006
    51
    thank you dpuch, works great!!!
    Nov 2006
    51
    if you have varaibles 100-199 and 500-999 your 9937.4 worked
    Sep 2006
    9
    thanks, I was trying to find out on the High Speed skip when I turn on the parameter if the G31 would let me know if the proper hardware was installed.
    Jan 2007
    4
    Yes, you would need software to run measurements. The high speed skip input is on the back of the control screen(lcd), is the Ja40 Honda connector. If it's not enabled (View input F0122 on diagnosis) use the low speed skip.
    Hope i've been helpfull
    Feb 2006
    1792
    Quote Originally Posted by Bluesman View Post
    Bluesman
    How do you know all the option parameters?
    Recently, I got Dynamic Graphic feature activated on my 0i Mate TC, and Fanuc charged a hefty amount for this! They only changed an option parameter (9000 series) which took just one minute!
    They told me that, on newer control versions, such things cannot be done using option parameters. Encripted files come for every control model and every serial number.
    Nov 2005
    274
    Quote Originally Posted by sinha_nsit View Post
    I have no option parrameters.
    Bluesman
    Jan 2009
    22
    hello all
    This question I had ask the bj-fanuc co,ltd ,they told me that, the newer control ,if you change a card of the nc ,you must need a new Encripted file. It only made by the fanuc!
    Otherwise the nc only can run 720 hours.
  17. #17
    Mar 2009
    6
    Maybe this will help you
    N09000 P 00000000
    N09001 P 0
    N09002 P 0
    N09003 P 0
    N09010 P 00000000
    N09011 P 00000000
    N09900 P 5
    N09901 P 0
    N09902 P 0
    N09920 P 01011010
    N09921 P 11100010
    N09922 P 00000100
    N09923 P 10001100
    N09924 P 00111111
    N09925 P 01100000
    N09926 P 01110000
    N09927 P 01011010
    N09928 P 10100000
    N09929 P 01101111
    N09930 P 00110000
    N09931 P 01100110
    N09932 P 10010100
    N09933 P 10000000
    N09934 P 01010110
    N09935 P 00100000
    N09936 P 10100101
    N09937 P 00101111
    N09938 P 00000000
    N09939 P 00000000
    N09940 P 10000100
    N09941 P 00000001
    N09942 P 00000001
    N09943 P 00011000
    N09944 P 10000000
    N09945 P 00000000
    N09946 P 00000100
    N09947 P 00000000
    N09948 P 00000000
    N09949 P 00000000
    N09950 P 00000000
    N09951 P 00000000
    N09952 P 00000001
    N09953 P 10000000
    N09954 P 00000000
    N09955 P 00000000
    N09956 P 00000000
    N09957 P 00000000
    N09958 P 00000000
    N09959 P 00000000
    N09960 P 00000000
    N09961 P 00000000
    N09962 P 00000010
    N09963 P 00000000
    N09964 P 00001000
    N09965 P 00000010
    N09966 P 00000000
    N09967 P 00000000
    N09968 P 00000000
    N09969 P 00000000
    N09970 P 00001000
    N09971 P 00000001
    N09972 P 00000000
    N09973 P 00000000
    N09974 P 00000000
    N09975 P 00000000
    N09976 P 10000001
    N09977 P 00000000
    N09978 P 00000000
    N09979 P 00000000
    N09980 P 00000000
    N09981 P 00000000
    N09982 P 00000000
    N09983 P 00000000
    N09984 P 00000000
    N09985 P 00000000
    N09986 P 00000000
    N09987 P 00000000
    N09988 P 00000000
    N09989 P 00000000
    N09990 P 00000000
    N09991 P 00000000
    N09992 P 00000000
    N09993 P 00000000
    N09994 P 00000000
    N09995 P 00000000
    N09996 P 00000000
    N09997 P 00000000
    N09998 P 00000000
    Take care with any parameters mods!!!
  18. #18
    Jan 2009
    22
    dear moowod
    it there your parameter upload from the machine ?
    Fanuc co. add a funtion to the control that is use a "cnc opset.txt" file.
    The file's content most like this:
    N99000P0P4P6P8
    N99001P39715P51747P61796P39414
    N99002P45483P65361P25979P19780
    N99003P201P34475P64374P28275
    N99004P28356P60405P25531P44021
    N99005P55747P27383P58848P27491
    N99006P24238P356P55551P61729
    N99999P0P4P5P6
    It only use for Serial NO :EO86B3174
    Open the AICC funtion.
    of course ,if you known how to write this file.
    you also could open a funtion for a control.
  19. #19
    Oct 2010
    3
    Re: Fanuc 18i custom macro B
    Quote Originally Posted by wujp View Post
    dear moowod
    N99000P0P4P6P8
    N99999P0P4P5P6
    Dear Wujp,
    Do you have the CNCIDNUM.TXT file before/after option changed?
    May i see those files?
  1. Peter Smid Fanuc Cnc custom macro's handbook.
    By Chevalier180D in forum Machinery Manuals / Brochures
    Last Post: 03-03-2013, 08:51 PM
  2. Replies: 2
    Last Post: 12-19-2012, 01:28 PM
  3. Replies: 6
    Last Post: 01-14-2012, 07:17 AM
  4. Fanuc custom Macro Question????
    By ixoxi999 in forum Fanuc
    Last Post: 12-08-2011, 11:31 AM
  5. Fanuc Custom Macro
    By acrisius00 in forum Coding
    Last Post: 02-11-2011, 06:02 PM
