586,036 active members*
3,706 visitors online*
Thread: Fanuc 18i-P
Results 1 to 18 of 18
    Sep 2018
    9
    Post Fanuc 18i-P
    We need help how to upload machine software and parameter files to machine Amada Europe 258 with Fanuc 18i-P.
    We have machine files for Amada Europe 258 on SRAM disk:
    A8DX_04.MEM
    P903_01.PAR
    P903_01.PMC
    P903_01.TOL
    M9X3_01.MEM
    A8DX_04.MEM and M9X3_01.MEM uploading is successful, but we can not upload .PAR, .PMC and .TOL files. When try to upload .PAR, .PMC and .TOL files in the machine we receive error SRAM0_5A.FDB NOT FOUND
    Any help?
    Should we convert .PAR, .PMC and .TOL to .FDB file and how?
    Attached Files Attached Files
    Re: Fanuc 18i-P
    The PAR, .PMC and .TOL files have to be loaded via the RS232 port not the Boot mode
    Sep 2018
    9
    Re: Fanuc 18i-P
    You mean that we have to upload only MEM files through boot mode? Than how to proceed to loading via the RS232?
    We do not receive main screen of the machine after loading MEM files.
    Re: Fanuc 18i-P
    I can't see the attached files. What problem did you have that made you believe that you needed to load these files? The MEM files are stored in FLASH memory and don't need to be loaded.
    Apr 2006
    111
    Re: Fanuc 18i-P
    Par file is parameter
    Pmc file is pmc parameter
    Tol file is tool setting
    Mem file is flash memory file
    Sep 2018
    9
    Re: Fanuc 18i-P
    During replace of the monitor screen, we have disconnected battery. From this point we have lost main machine screen, with Amada logo and all other options. On normal start up we have black screen. On service start up we have system main menu with options as 1. system data loading 2. system data check............
    We need help how to revert back to main machine screen to operate the machine
    https://en.industryarena.com/forum/a...5&d=1605972156
    check the picture of the main machine screen we are missing
    Apr 2006
    111
    Re: Fanuc 18i-P
    Quote Originally Posted by ozonair View Post
    There is a way to replace the screen without removing the battery.
    If you lost option, You should contact to Amada
    Oct 2009
    297
    Re: Fanuc 18i-P
    I agree with "drdos". You must be doing something wrong. If you cannot see anything on the screen, how do you know you lost the memory? There are some LEDS in the yellow case, in the back of the screen on the main pcb. Would you please send some photographs?
    regards
    Alex Fanuc
    Sep 2018
    9
    Re: Fanuc 18i-P
    HI,
    Here is what we see on the leds behind the screen.
    Due to covid restriction it was not possible to get Amada assistance on site and we have decided to make the change of the monitor screen by ourselves, and we have problem now. Now screen is working, but machine is not working.
    Sep 2018
    9
    Re: Fanuc 18i-P
    Here are also all pictures from the screen in boot mode and content of submenus.
    Sep 2018
    9
    Re: Fanuc 18i-P
    and other submenus
    Apr 2006
    111
    Re: Fanuc 18i-P
    See nothing. Reupload pictures please
    Sep 2018
    9
    Re: Fanuc 18i-P
    HI,
    Finally we have succed to revert back the main machine software and screen.
    We have uploaded SRAM0_5A.FDB from other Amada Europe 258 - same machine and now we have main screen back.
    Up to now successfully loaded in the machine:
    A8DX_04.MEM
    M9X3_01.MEM
    Can we have instruction how to load original par, pmc and tol files:
    P903_01.PAR
    P903_01.PMC
    P903_01.TOL
    Thanks,
    Apr 2009
    1379
    Re: Fanuc 18i-P
    in selecting I/O CHANNEL enter '4' (MEM CARD) see section 8.11 of B–63124EN operation manual.
    Sep 2018
    9
    Re: Fanuc 18i-P
    HI,
    In 8.11 there are several options. Which one is for SD card to Machine transfer of PMC, TOL and PAR files?
    8.11.1 - Setting Input/Output–Related Parameters
    8.11.2 - Inputting and Outputting Programs
    8.11.3 - Inputting and Outputting Parameters
    8.11.4 - Inputting and Outputting Offset Data
    8.11.5 - Outputting Custom Macro Common Variables
    8.11.6 - Inputting and Outputting Floppy Files
    8.11.7 - Memory Card Input/Output
    8.12 - DATA INPUT/OUTPUT USING A MEMORY CARD
    We have PAR, TOL and PMC files on SD card
    Apr 2009
    1379
    Re: Fanuc 18i-P
    " We have PAR, TOL and PMC files on SD card" use 8.12 - DATA INPUT/OUTPUT USING A MEMORY CARD. You will need a sd card to pmcia adapter.
  17. #17
    Sep 2018
    9
    Re: Fanuc 18i-P
    HI,
    We have succeed to insert PAR file, but we are not sure how insert TOL and PMC files. On which tabs, or how to proceed inserting TOL and PMC files?
  18. #18
    Feb 2018
    Re: Fanuc 18i-P
    please you didn't upload sram links to me
    I also have amada 258 europa punch sram deleted
