587,691 active members*
3,661 visitors online*
    Hello
    My company is going to equip Fanuc 20T for DNC transfer. Is a zero-modem-cable between PC and controller enough or should the cable have a special configuration? If it should, where can I find it?
    Greetings
    Hi
    It has to stand in the documentation!!!
    The symbols for controlling of the RS232 port have to be set. You’ll find it in the manual or in the setting of the machine. If you don’t have any documents…
    Good luck
    Good luck
    I believe you confused him more than you helped.
    @kabelman
    I’m not well versed in the 10T but the machine manufacture can usually help in such cases.
    You’ll also find literature or tips and tricks about data transfer and Fanuc in the Internet.
    It’s late now, otherwise I’d search for you.
