587,842 active members*
3,439 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC 20-M: Cannot write PMC data (Write protect)
    Jul 2016
    8
    I apologize for the cross-post, this appears to be more related to the FANUC channel.
    After buying a machine with a dead battery, I have reinstated almost all parameters. The last bit I need to do is to modify the PMC data. Unfortunately I cannot write to these data; I get a "write protect" error every time.
    What is the standard method for writing to PMC data? I have tried in MDI, EDIT, e-stop on and off, "Parameter Write" enabled and disabled (under Offset Setting x2). I've googled the heck out of this but cannot find an answer.
    Thank you for any help!
    Jul 2016
    8
    Re: FANUC 20-M: Cannot write PMC data (Write protect)
    Of course I figured it out after asking twice. Fortunately in another post, someone explained the "Parameter" byte value one screen up. In my parameter list, it says that this value must be 00000010; according to the other post this would be for "decimal with write protect". I am still fuzzy on this, as the screen still shows "BIN" highlighted (even with BCD I would expect this to be entered in binary format). Either way, by changing this to 00000000, I was able to remove write protect and get my values in. Of course, change this back to write protect afterward.
    The other post is linked here: https://www.cnczone.com/forums/fanuc...ata-pages.html
    Shoprag, thank you for sharing that textbook page!!!
  1. Replies: 4
    Last Post: 06-06-2023, 04:27 AM
  2. 300- alarm. write protect
    By alexandermatovu in forum Fanuc
    Last Post: 06-23-2012, 01:56 AM
  3. Fanuc 11m parameter write protect
    By BrianM03 in forum Fanuc
    Last Post: 06-14-2010, 04:17 PM
  4. Replies: 8
    Last Post: 04-30-2010, 11:54 AM
  5. FANUC 15T Write Protect
    By bmlw in forum Fanuc
    Last Post: 10-11-2008, 08:47 PM
