603,299 active members*
2,386 visitors online*
Results 1 to 7 of 7
    Mar 2017
    FANUC 21i-T enable ex-edt
    *EDIT*
    Machine is '98 Romi M17 Fanuc 21i-TA Control
    Need option parameter passwords and password input procedure.
    I know what to change parameter 9936 to, but it wont accept it without password unlock sequence.
    please help!
    Feb 2006
    1792
    Re: FANUC 21i-T enable ex-edt
    It is a basic feature. Are you sure it is not available on your machine. Try this:
    Set parameter 3204#2 to 1 (3204#0 should remain 0; status of the other six bits does not affect this feature):
    Such a parameter setting displays an extended character set, as soft keys, in the EDIT mode, displaying “(“, “)” and “@”.
    With this setting, if square brackets are needed, use the bracket keys on the MDI panel, and if parentheses are needed, do the following (in EDIT mode):
    • Press PROG on MDI panel (press PROG again if the current program is not displayed).
    • Press the OPRT soft key.
    • Press the right extension key (>) twice.
    • Press the C-EXT soft key.
    After this, soft keys for left parenthesis, right parenthesis, and @ (which can be used in the comments inserted in a program) will appear which can be used as and when required for editing in EDIT mode.
    Mar 2003
    2932
    Quote Originally Posted by ITMfg View Post
    *EDIT*
    please help!
    Sinha:
    3204.0 is "Input Character Extension", and 3204.2 is "PAR" function, neither of which is Extended Editing, which is an OPTION.
    It is easy to unlock simply call 1-888-FANUCUS (888-326-8287). They will be than happy to assist you.
    Feb 2006
    1792
    Dcoupar,
    What is the extra flexibility with extended editing?
    Mar 2003
    2932
    Quote Originally Posted by sinha_nsit View Post
    Dcoupar,
    See attached Description.
    Feb 2006
    1792
    I have seen these functions on a vary basic low-cost 0i Mate machine. I thought these are standard. At least it should not be an option on a higher control version. But, Fanuc is Fanuc.
    Incidentally, this book of mine explains all these editing techniques in quite detail:
    https://www.amazon.com/CNC-Programmi...=UTF8&qid=&sr=
  1. Enable Fanuc OM-D 4th axis
    By pinguS in forum Fanuc
    Last Post: 03-12-2024, 09:11 AM
  2. how to enable 48 WPC on fanuc O MC
    By joseelmo in forum Fanuc
    Last Post: 03-09-2016, 05:51 PM
  3. Enable shift key for Fanuc 6M.
    By ckirchen in forum Fanuc
    Last Post: 02-04-2012, 11:13 AM
  4. Fanuc OM-B G52 Offset Enable
    By NCEd in forum Fanuc
    Last Post: 05-29-2011, 07:36 AM
  5. Fanuc 18-T G83 cycle enable
    By CoffinJoey in forum Fanuc
    Last Post: 12-27-2010, 08:32 PM
