603,936 active members*
3,118 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > fanuc 21t parameter lock needs unlocked
    Jun 2012
    Hi.
    I obtained a Doosan S310 with a tailstock. I can't move the tailstock and found a hand written note that said the tailstock parameter was turned off. It is parameter 2062 (from memory). Sure enough it is marked "0". The control is a Fanuc 21T. Pressing the button to turn it on gives us a flashing message "wrong mode" (one time) and later a different one.
    I think I need to turn off the parameter lock but not being familiar with this control I am just stumbling around.
    Can anyone give me a hand?
    Feb 2009
    6028
    Mdi
    Setting
    Pwe=1
    Nov 2007
    365
    The Tail Stock should have a clamp unclamp button on the panel?
    In manual this should unclamp the Tailstock carraige and move a pin forward towards the turret------there should be a hole at the bottom side of the turret that when you move the Z-axis back it fits into ?
    If this is the one the z axis is what moves it forward
    The Sleeve/Quill will come in and out with an M code and if turned off will be a keep relay on the System/Pmc/Keep page
    Do a search for the M code that moves the Sleeve in and out in the ladders and you should find the Keep realy turning it off
    M78 should be sleeve forward
    M79 should be back
  1. Replies: 15
    Last Post: 07-09-2020, 09:08 PM
  2. Replies: 6
    Last Post: 02-17-2016, 08:12 PM
  3. Fanuc 11 G54 parameter
    By staffb68 in forum Fanuc
    Last Post: 06-26-2013, 08:21 PM
  4. Fanuc OM DNC Parameter
    By amurphysmu in forum Fanuc
    Last Post: 11-20-2009, 12:16 AM
  5. lock programs with fanuc 16/18 control
    By Heavy D in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-31-2006, 12:09 AM
