587,424 active members*
3,305 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 31i Protection of Data at 8 Levels
Results 1 to 13 of 13
    Aug 2013
    20
    Question Fanuc 31i Protection of Data at 8 Levels
    Hello guys,
    I have a problem on my CNC machine with a Fanuc 31i MODEL A5
    I can't edit some CNC parameters such as 1815 to set the zero reference for the axis
    I set the PWE to 1
    Switch the Write Enable Key from my Control panel
    But when i try to edit this parameters the Write Protect appears
    Also when i try to restore the CNC Parameters from my SD-Card the Write Protect appears at the screen.
    I searched for this problem on the Fanuc manual and i found something called Protection of Data at 8 Levels
    I found that my machine works on level 0 so i don't have the access to this parameters
    When i want to change the level to 4,5,6 or 7 it needs a password which i don't know !!
    So does anybody know the default password for changing the operation levels ?
    If the password differs from machine to another can we found it on the ladder file or in the SRAM file ? i means reverse engineering process to know this password ?
    Greets
    Apr 2009
    1379
    Interesting questions. Is your control a 21iA or 21iB?
    I have never heard of "Protection of Data at 8 Levels". Which manual is this in?
    Aug 2013
    20
    Hello memoryman,
    The control is 31i MODEL A5
    The manual is FANUC Series 31i/310i/310is-MODEL A5 USER’S MANUAL (Volume 2 of 2) (63944ENV2)
    Apr 2009
    1379
    Thank you. I did not have that manual.
    "If the password differs from machine to another can we found it on the ladder file or in the SRAM file " I have done that successfully on the FS11, but need the following:
    1: the data is not encrypted in the sram file
    2: a sram file with the password and
    3: a sram file with a new password (even blank) and
    4: that new password
    Better to do steps 3&4 twice with different passwords.
    Aug 2011
    2517
    you mean 2 & 3 ;-)
    a simple binary file compare would do the job then just blank out the pass or paste the changed bytes (the new known pass) into the file where the bytes differ, save it then read the SRAM back into the machine.
    Feb 2009
    6028
    Some of those passwords are the rotating passwords that Fanuc only has.
    Apr 2009
    1379
    don't forget that the time stamp also changes; if a checksum is used, the cut and paste won't work.
    Aug 2011
    2517
    it wouldn't really matter as long as it's not encrypted the changed data can be seen using a hex editor so the actual password would be easy to find. then just type it in.
    Jul 2010
    118
    hi,
    the standard password for level 4 is in the manual, which the mtb should give to the dealer for maintenance reason.
    you need level 4 to change parameters.
    you will never need to access level 5-7, this is for mtb and fanuc.
    caution, these passwords are not represented in a parameter, so should you change and forget there is no reversal.
    have fun
    norbert
    Aug 2011
    2517
    Quote Originally Posted by norbert.barnard View Post
    Which manual? I checked the FANUC Series 30i/31i/32i-MODEL A USER’S MANUAL (Common Volume 2 of 2, 63944ENV2). There is brief information about 'Protection of Data at 8 Levels' but no default password is listed for level 4.
    Jul 2010
    118
    connection function, B64438en-01.
    Aug 2013
    20
    Thank you i will test this method
    I can't find this manual !!
    Aug 2011
    2517
    it's not part of the 30i/31i/32i manual set. it may be for a later model but there's 0-hits in google so it probably doesn't exist.
    the 30i/31i/32i Model A connection function manual is B-63943en-1/02
    The parameters can be set with G10L50 regardless of the protection level anyway so it's not really needed. The manual says.....
    The initial values of the passwords for operation
    levels 4 to 6 are shown below.
    - Operation level 4: "HC3V9ZEP"
    - Operation level 5: “J72WB8YA”
    - Operation level 6: “VLR6T92M”
    Change protection checking of data basically
    covers the changes made by MDI operation. The
    changes made by operations are not covered.
    For example, programmable parameter input by the
    G10L50 command can be changed regardless of
    the operation level or the change protection level of
    the parameter.
  1. Fanuc data sheets
    By RP Designs in forum Servo Motors / Drives
    Last Post: 05-20-2009, 04:20 AM
  2. FANUC 10T DATA TABLE
    By DIE FAST in forum Fanuc
    Last Post: 01-09-2009, 07:02 PM
  3. Fanuc O-M data
    By rajesh_1355 in forum Fanuc
    Last Post: 06-18-2008, 03:24 PM
  4. Fanuc 18i with Data Server
    By Monty66 in forum Fanuc
    Last Post: 02-13-2007, 04:23 AM
