I have a Robodrill Alpha T14e with a 31i control that I cannot get RS232 set up correctly.
As far as I can tell, I have this control set up exactly as my Robdrill Mate running an Oi control that works just fine. I am using the same RS232 cable to eliminate potential errors.
Using channel 0 for RS232 In/Out
Baud Rate set at 11 for 9600
Stop Bits at 2
Parity is Even
The communications software is set up to reflect the above information and like I said, my other Robo works just fine.
Is there another parameter or setting that I am missing? Perhaps something different or extra from the Oi and 31i control?
I should also mention that this machine was recently purchased used and it lost the SRAM right of the bat because of a weak backup battery. The SRAM was reloaded by the local dealer but the communications did not get tested before the tech left.
Any suggestions? Any other details I need to provide?
