Hi
i have fanuc wire EDM,
control unit is fanuc 18i-w
i get an error message the machine starts.
u , V axis inverter alarm 449
was once a while, and then re-opened the issue is resolved.
but now is not being solved.
Hi
This happens before you push the control ON button right? Then the problem is the servounit itself.
Had the same problem last week. If you get the alarm after turning on
main power and you have not pushed control on.
It is the servo amp. You will have to replace it.
You must replace or repair the servounit A06B-6096-HXXX
Good luck!
