586,042 active members*
3,874 visitors online*
    Dec 2010
    6
    Fanuc 5T Error/Boot problem
    If anyone has info regarding this problem any advice offered would be appreciated.
    Fanuc 5T on Hitachi 6NE lathe.
    Machine seldom used. Started occasionally to run spindle, tool changer etc, basically cycle machine.
    Historically this process ran OK.
    Recent year or so machine has deteriorated. Problem commenced with self shutdown of spindle etc after 30 minutes or machine running. Reboot and restart of control fixed problem. Progressively run time to error became shorter.
    Then problem progressed to machine shutdown with control interface freezing. This problem overcome by power off and/or removal of memory batteries cleared for extended periods.
    Now problem is at very start of power up of 5T controller which produces; either all LEDs under the parameter letters lit and remaining so OR progresses past this above stage to what I think is next stage of boot sequence at which it stops. Here is displayed 41 20. These numbers are in the positions of ISO (4), RMT (1), and Number (20).
    No idea what these mean or how to fix.
    Code means?
    Is this a board problem?
    Could this be wiring integrity issue?
    Regards
    Frank1
    Aug 2018
    44
    Re: Fanuc 5T Error/Boot problem
    You have on each pcb 2 whites power connectors.
    Please check and clean, you have a poor connection.
  1. fanuc oi-td boot system backup problem!!!!
    By Nano-cr in forum Fanuc
    Last Post: 05-02-2016, 01:16 PM
  2. Fanuc 10 t problem OT 117 error
    By miki11 in forum Fanuc
    Last Post: 12-22-2014, 07:51 PM
  3. Hurco KM-3P Boot Error
    By nuzmeed in forum HURCO
    Last Post: 08-18-2011, 06:53 AM
  4. A2100/NT boot error
    By kentsui in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-14-2008, 10:44 PM
