587,940 active members*
3,047 visitors online*
Results 1 to 4 of 4
    Aug 2006
    32
    fanuc 6m 421 alarm
    Kitamura 1982 or so
    I get intermittent 421 y servo alarm
    i took the covers off and ran it no tool and ran fine
    It seems right when I have a job to do
    it alarms
    any Ideas
    Thanx
    Joe
    Aug 2006
    32
    It also seems that when the alarm happens, and I reset
    if I don't touch the ballscrew it will alarm again.
    If I turn the screw by hand (even an 1/8 turn ) it will go ,as in home Y
    There is also no binding that I can feel when I turn screw by hand
    thanx
    Joe
    Aug 2009
    12
    I had a little smash on Z axis on daewoo puma 6 m control now I canot get away with 420 or 421 alaram machine worked fine
    Aug 2009
    12
    421
    Quote Originally Posted by actionman View Post
    thanx
    Joe
    It might be your cover they are giving load to the ball screws
    it might be your gibbs are loose or too tight and they are giving errors to Y axis servo
    check the limit swithes make sure there are no chips there
