603,373 active members*
4,375 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 6M: Converting paper tape to computer file
Results 1 to 12 of 12
    Mar 2007
    158
    I need to convert a paper tape into a computer file so that I can later load it via RS232 and also so I can print it out.
    Due to a settings problem, I cannot do this in the normal way by loading the tape into the machine's memory and then downloading the memory to the computer via RS232.
    Is there a way to run the tape reader in manual mode and dump the output directly to the RS232 port for capture on the computer?
    If not, is there anyone who can convert my tape to a file for a fee?
    Thank you,
    PhoenixMetal
    Wow ancient history. Good luck finding someone.
    Dec 2003
    24260
    Some time ago, I put together a Fanuc reader and built a RS232 interface from a old USART chip, the reader is parallel data, so it has to be converted to serial for RS232.
    I believe I still have it somewhere.
    Is this a parameter Tape?
    Al.
    Albert E.
    Mar 2007
    158
    Quote Originally Posted by Al_The_Man View Post
    Al.
    Hi Al, wow that's really great if you could dig that thing up. Yes you are correct - it is a parameter tape. If you can find the device, the please give me a price and I'm sure we can work together. Thank you!
    Dec 2003
    24260
    I have dug it out, later today I will make sure it still works by running a tape through.
    Al.
    Albert E.
    Jun 2007
    3738
    Question How long is it?
    If the tape is fairly short, you could hand decode it. A bit painful but doable.
    I have a PTR and punch, with RS232 but I am a long way away. Sending an important irreplaceable tape is a high risk due to loss or damage.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Mar 2007
    158
    Hi neilw20, the tape is quite long so hand-decoding would be quite tedious and error-prone. I see you are in Australia - wow,that is is quite a ways away, so perhaps sending it there is a greater risk than within the US or Canada... Thank you though!
    Jun 2007
    3738
    Question
    Quote Originally Posted by PhoenixMetal View Post
    You can't get much further away than NY. ! What sort of machine is this on?
    Mar 2007
    158
    The tape is for a Wiedemann Centrum 1000 Turret Punch Press with a Fanuc 6M control.
    Dec 2003
    24260
    I have it tested, I ran a Fanuc 0 tape through that ended up at 4K+.
    If you want to Pm me I can give you an address to send to.
    Al.
    Albert E.
    Sep 2005
    767
    If this parameter tape has been loaded into the control, why not just punch out the parameters through the 6Ms serial port. To do that, display the parameter page, put the control in EDIT mode, then press "P-9999" then PUNCH. This would give you an accurate backup of the parameters that are in the CNCs memory, which may be a bit different than what's on that tape.
    You can connect a Fanuc parallel tape reader directly to a PCs parallel port and read in a tape, but that would require a special cable and special software for the PC. Al_the_man's serial adapter may be a much easier solution.
    Mar 2007
    158
    Hi Dan,
    The reason I am not simply punching out the parameters that are already saved on the CNC is because Wiedemann thinks that some of the parameters have been corrupted. That is why I want a fresh load of the parameters from the original tape.
    I have no problem making a custom cable, and maybe I'll have to go down that route, but first I would like to see what can be done with Al_The_Man's solution.
  1. Contact Paper as transfer tape
    By tauscnc in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 11-03-2007, 11:05 PM
  2. question about file converting
    By cncmachiningzon in forum Solidworks
    Last Post: 04-14-2007, 04:51 PM
  3. I need to build a paper tape emulator
    By paramax55 in forum CNC Machine Related Electronics
    Last Post: 04-11-2007, 10:40 PM
  4. Converting a File
    By Tazzer in forum ArtCam Pro
    Last Post: 10-30-2005, 11:52 PM
  5. Converting a .max file
    By DAB_Design in forum Uncategorised CAM Discussion
    Last Post: 01-28-2005, 08:00 PM
