how and where do you enter a cutter comp (D01) offset on the 6m
Hi, If it is like my older 0M control, there is just a register of offset numbers and do not have regard to "H" or "D". You simple keep them seperate conciously. When you determine D33 say, it just goes to the register and reads the value in #33 . The same if H33 was used, same value. Hence you are the control not to use them twice.
Hope this is true for your control.
dlb
On the 6m machines I have run the tool registry was set up for 99 tools but we only had a 40 tool changer. So we designated #41 as the cutter comp slot for tool 1.
