588,585 active members*
13,744 visitors online*
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Mar 2003
    2932
    Re: Fanuc 6m RS232 help
    Quote Originally Posted by awemawson View Post
    It is because the Fanuc only sends 'Line Feed' as end of line, not CR/LF
    If it's a 6M-B then parameter 8 bit 7 can be set to 0 to output "LF CR CR" or 1 to output "LF".
  2. #22
    Jul 2022
    6
    Quote Originally Posted by lmostafa View Post
    I have a machine center MORISEIKI MV35/40.fanuc6m
    For the transfer from machine to pc it works
    To transfer from the PC to the machine it works
    But DNC mode the machine does not work
    when push start boton cycle start dhe green led lit ut dhe machine not work
    help me plees
    beste regard
    Can you send me a picture of your first PC parameters please [email protected] or wrapped 442 476 0463
Page 2 of 2 12
  1. Using RS232 on a fanuc 10m
    By davidrvalencia in forum Fanuc
    Last Post: 05-20-2021, 07:24 PM
  2. Fanuc 11M RS232
    By 9566317 in forum Fanuc
    Last Post: 09-24-2015, 10:02 AM
  3. Fanuc 31i RS232 Help
    By haastec in forum Fanuc
    Last Post: 01-06-2014, 05:18 PM
  4. fanuc 0t rs232
    By rvila in forum Fanuc
    Last Post: 04-02-2010, 06:02 PM
  5. Fanuc 31i-A , RS232, DNC
    By padobranac in forum Fanuc
    Last Post: 01-25-2009, 04:52 PM
