587,997 active members*
2,010 visitors online*
Results 1 to 4 of 4
    Feb 2010
    Fanuc 6t parameter
    Hi All,
    I have Mori-seiki 4ne-600 cnc machine and I have a problem with the spindle
    which its not rotate .I try to measure the voltage output of the D/A converter .I found it cann't reach +/-10v -the max reading is 1.66v-
    so Any one can help me in finding Fanuc 6t parameter Definition ?
    At least the parameters regards to spindle?
    thanks
    Apr 2007
    13
    Try to change parameter nos.
    119 Spindle speed offset compensation value ( for S4-digit analog output A/B )
    setting amount 0 - 8191
    140 Gain adjustment of S4-digit analog output A/B
    setting range 700 - 1250
    standard setting 1000
    May 2007
    42
    Check Run(forward or reverse) signal
    If you have more 1.0volt command voltage, spindle must run any spped.
    First of all ckeck the "RUN" command logic signal is "High" or not.
    Good luck!
    Aug 2008
    153
    Mori/Hitachi 4NE-600
    This machine uses somewhat of a strange method for generating the analog for the Fuji DSR Compact drive. The Fanuc connection unit has a 12 bit binary output to a custom D/A converter that is tucked in behind and to the left of the spindle drive. I've seen one case where the Fanuc connection unit (located under the CRT) had one bad binary bit and it caused this type of problem. If you have access to another Fanuc 6T, you might try swapping the connection units. They are the long (19") narrow boards.
    Warren
    www.uptimecorp.com
  1. Fanuc parameter 901
    By mistux in forum Fanuc
    Last Post: 12-04-2009, 06:28 PM
  2. Need help with Fanuc 6MB parameter
    By nguyenthanhthi in forum Fanuc
    Last Post: 07-24-2008, 05:15 AM
  3. Fanuc 0T parameter
    By Master_CNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-26-2007, 08:15 PM
  4. Need help with Fanuc 6MB parameter
    Last Post: 10-22-2007, 02:12 AM
  5. parameter fanuc om-d
    By dlmusinage in forum Fanuc
    Last Post: 05-17-2006, 10:54 PM
