603,826 active members*
5,508 visitors online*
    Jan 2010
    321
    Fanuc 6t rs232 stopped working
    I have been transferring data flawlessly from nc link to my lathe by rs232 for some time but today I fired it up after a few weeks of not being used and I can't get the data transferred. At the control I select edit and press read and edit flashes on the screen. On the pc I select the file and select my fanuc machine and nothing happens at either end. My pc and program work as I transferred files to my fadal mill today without trouble.
    I have checked the cable and if seems fine but am happy to remake it if they are reported to be unreliable.
    Where to look next. Any ideas.
    Jan 2010
    321
    Well I did some research and it would seem that I need to check the signals coming out of the fanuc serial port. If they don't check out then if could be either a master pcb or a puncher card. Does anyone have an idea on testing the serial port?
    Jan 2010
    321
    Have ordered a serial break out box to fault find the port. i had a play around with different calbe configurations tonight and i managed to get a program to load but then i tried again and nothing just a 086 alarm. i have since googled every different cable configuration that i can find and some gave an error straight away and others didn't.
    currently the cable set up i have uses pin 4 to turn on pin 6 and 8 instead of using the fanuc pin 20.
    this current cable doesn't give me any alarms but just no data transfer i guess untill the breakout box arrives i am flying blind
  1. Mazatrol Cam M2 stopped working !!!
    By black in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-17-2013, 07:24 PM
  2. Fanuc 10T serial port stopped working
    By jolulank in forum Fanuc
    Last Post: 07-22-2011, 04:46 PM
  3. SX3 Stopped Working
    By mikemill in forum Syil Products
    Last Post: 01-09-2009, 04:54 PM
  4. steppers stopped working?
    By bigz1 in forum Machines running Mach Software
    Last Post: 12-11-2006, 10:39 PM
