603,975 active members*
3,284 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 6t, spindle runs in manual but not commanded.
Results 1 to 10 of 10
    Jan 2009
    245
    I have a fanuc 6t. The spindle will run in manual and change speed with the speed pot. In auto, as in commanded mdi, the main spindle contactor will energize but the spindle will not turn. Any ideas?
    Jan 2009
    245
    So from my limited research. Looks like the Control sends a voltage to the spindle drive. It sends from 0-10v to go from the Smin to the Smax. Where can I test to see if the spindle drive is getting an analog signal from the control?
    Oct 2009
    300
    Check for the following:
    Door closed?
    Chuck closed?
    Did you comand an M41? (to change gear) it depends on the machine.
    Regards
    Alex
    Jan 2009
    245
    Yes, two all three of those.
    Jan 2009
    245
    Some info
    Attached Thumbnails Attached Thumbnails spindle schematic.jpg   spindle drive_0001.jpg   spindle drive_0002.jpg   spindle drive_0003.jpg
    Oct 2009
    300
    Look at the master pcb, is there a cable connected to C08? (left bottom side of the master pcb)
    What kind of machine do you have? because I think the voltage is coming from the Fanuc I/O board.
    Jan 2009
    245
    It is a miyano 6bc. I also swapped io voard and did not help.
    Nov 2007
    365
    Auo run conditions are different
    Pull up the ladders and look which part of the statment is not coming on
    I would suspect limit switiches on the chuck for part pressent or hydraulic pressure switch -----door closed limit switch ---axis at home position ?
    has it got a tail stock----is it reading quil retracted/tail stock clamped down ?
    Oct 2009
    300
    Ok, ladder cannot be seen in this type of control. I´ve seen machines that when the door is open the spindle will not run. It will run in mdi mode! so you must be sure that the door is closed checking the diagnostics page.
    Also, try m41 and m42 in mdi mode. Does the machine change the spindle gear?
    Regards
    Alex
    Jan 2009
    245
    There is no gear changer on this machine. But for the heck of it I did try M41, M40, M42 and did not help. Do you know what diag number and what bits to look for in the diag page for the door closed?
  1. Replies: 26
    Last Post: 04-17-2020, 07:06 PM
  2. Replies: 12
    Last Post: 07-25-2012, 11:10 AM
  3. Fadal runs and runs and runs awayyyy!
    By pbrokaw in forum Fadal
    Last Post: 01-16-2012, 03:26 PM
  4. 197 C-AXIS COMMANDED IN SPINDLE MODE
    By padobranac in forum Fanuc
    Last Post: 05-04-2010, 11:45 AM
  5. Manual for Fanuc Spindle Orientation board
    By MetLHead in forum Fanuc
    Last Post: 02-14-2008, 09:23 PM
