603,316 active members*
3,049 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Fanuc AC Spindle Motor Model 3 on Delta C2000 5.5KW
Results 1 to 4 of 4
    Mar 2023
    im running in trouble to setting up my Delta C2000 VFD with a Fanuc AC Spindle Motor Model 3. I want to do fully cloesd loop with a ABZ Encoder on the Spindle Shaft.
    I´ve already read many many threads about setting up AC Spindle induction Motors with a VFD. The most using sensorless vector control with a V/F table.
    The problem is: Delta C2000 only offers two modes to running closed loop induction motor. 1. freq/volt Control with feedback 2. FOCPG field orientated vector control with feedback.
    My Motorspecifications on the motor plate:
    Fanuc AC Spindel Motor Model 3
    cont./30min. 3.7 / 5.5 KW
    cont./30min. 17 / 22 Amp
    Volt: 200v
    Poles: 4
    RPM 1500/6000
    The only way i can ordinary setup my motor ist in FOCPG (fieldorientated vector control with encoder) at following settings.
    Base Frequency: 200Hz (4 Poles = 6000rpm)
    Max Voltage: 200V
    Poles: 4
    rating power: 3.7kw
    17A
    The Problem is, that the relation between voltage and rpm is linear. so, low rpm low voltage = low torque, but i want to do tapping. So it is useless for me.
    If i using sensorless vector control or frequency/voltage mode i cant ordinary setup the vfd. The motor is always over saturated with the voltage, make noise and doesnt move.
    But, Doing my math, my voltage at 50Hz 1500 rpm is : 3700RPM/17A/1.73 = 125V. With this parameters, the motor doesnt turn and is making noise.
    Have anyone a plan how to fix the low torque problem in FOCPG (fieldoriented vector control with encoder) on the Delta C2000 ?
    or is there a way to use a another control mode ?
    Regards
    Re: Fanuc AC Spindle Motor Model 3 on Delta C2000 5.5KW
    It seems Delta C2000 can not do the job, better use Fanuc original spindle amplifier.
    Mar 2023
    Another Thoughts. Is the spindle motor with his electrical specifications suitable for delivering full torque from zero revolutions?
    i´ve already searched for torque diagrams for the Fanuc AC SPindle Motor Model 3, but i can´t find anything usefull.
    Quote Originally Posted by xcr4nkx3 View Post
    Volt: 200v
    Poles: 4
    RPM 1500/6000
    Max Voltage: 200V
    Poles: 4
    rating power: 3.7kw
    17A
    Regards
    xcr4nkx3
    Just stumbled across this thread as I am about to receive my new 11kw 230V C2000 to drive my mitsubishi 3.7/5,5kw Spindle motor which has very similar spec to your Fanuc motor.
    Some questions followed by some points from me:
    What size/power C2000 do you have? Are you sure it can output enough amps for your motor?
    Do you have a power/torque curve for your motor?
    Have you run the auto-tuning in the drive which is required for FOC+PG control?
    In your drive you should have the following parameters for your motor:
    Base frequency: either 150 or 200Hz depending on your constant power region (you can get this from power/torque curve)
    Max voltage: 200V
    Poles: 4
    Rated Power: 5.5kw
    Full Load Current: 22A
    Once you input these parameters correctly you should have more luck. Let me know how you go.
    Cheers,
    Mezzajas
  1. Replies: 3
    Last Post: 06-23-2022, 11:06 PM
  2. Closed loop with Delta C2000 and 12000rpm 400hz spindle
    By jeeybee in forum Spindles / VFD
    Last Post: 11-15-2019, 02:21 PM
  3. Replies: 0
    Last Post: 03-06-2018, 08:41 PM
  4. 4.5KW spindle motor CNC router for wood
    By SPC-laser in forum News Announcements
    Last Post: 08-15-2012, 06:41 AM
