587,223 active members*
3,216 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc Alarm 438 - Z AXIS : INV ABNORMAL CURRENT
Results 1 to 5 of 5
    Sep 2007
    122
    Hello all,
    I have put a new motor on a Kasper (Rasoma) inverted lathe and it runs fine until I try high speeds (100% rapid) and I get a Fanuc Alarm 438. The screw seems fine and the ways look good. I did read the other thread - http://www.cnczone.com/forums/servo-...amplifier.html - and was going to try and "tune out" the motor temperature sensor. If that is it I can swap motors.
    Does anyone know the parameter for this? I have another motor but wanted to troubleshoot it a bit first.
    Jun 2004
    511
    Re: Fanuc Alarm 438 - Z AXIS : INV ABNORMAL CURRENT
    What control? I think you can jump out the thermal.
    Dec 2009
    968
    you didn't said why you decide to change the motor
    first try to dismount the coupling between the motor and the axis and run the motor 100% and check if something happend.
    if nothing happendt han you have a problem in the axis ballscrew or slideway
    abnormal current allarm is generated by the driver and not by the motor
    i had one month ago this with huge vibration of the motor when it stand still.
    when i installed a new driver i had on drive the abnormal current
    so i had to change the motor too for that to work
    so better try a new motor .
    Sep 2007
    122
    Thanks - I will try that.
    Dec 2014
    5
    Also Check break circuit, Brake connector properly, intermidiate workinkg of brake will also a cause for these alarm
  1. SV003 V abnormal current in servo
    By thesticker in forum Fanuc
    Last Post: 08-28-2016, 01:24 PM
  2. ABNORMAL CURRENT Fanuc Servo Amplifier
    By Robyr in forum Servo Motors / Drives
    Last Post: 10-06-2013, 05:48 PM
  3. VF1 Alarm 162 Y Axis Over Current
    By Bruce_Mowbray in forum Haas Mills
    Last Post: 06-06-2012, 09:49 PM
  4. VF-1 alarm 162 Y axis over current
    By regen in forum Haas Mills
    Last Post: 10-23-2008, 01:38 AM
  5. 438 Invertor abnormal current
    By bob1371 in forum Fanuc
    Last Post: 08-07-2007, 07:41 PM
