587,202 active members*
2,911 visitors online*
Results 1 to 5 of 5
    Feb 2017
    6
    Fanuc cnc series oi-md
    Hello guys, i need to find parameters for SBK and FEED HOLD buttons and i don't find anywhere about them. I search in parameters manual but nothing.
    Please help me.
    May 2008
    107
    Re: Fanuc cnc series oi-md
    Hello Butechi.
    You can see the activity of SBK and Feed Hold button by selecting the SYSTEM -> PMC-> PMCDGN-> STATUS to find down their address, then use it's address to find in the ladder.
    Feb 2017
    6
    Thanks for reply.
    Can the button FEED HOLD be activeted from parameters or i need to make modification in ladder?
    May 2008
    107
    Quote Originally Posted by Buterchi View Post
    Thanks for reply.
    Dear Buterchi.
    Usualy the FEED HOLD button activated in ladder and named as *SP( G008.5), the LED is *SPL(F000.4). You can see the status of these signal by selecting PMC-> PMCDNG-> STATUS-> key in G08-> Enter and see on sreen( remember that Fanuc named the address as 7-6-5-4-3-2-1-0, that's mean the righ most work is .0), or you can tracking it by entered it's address in ladder monitor( usualy it's allways used OC contact, what's that meaning of * signal).
    Feb 2017
    6
    Hello guys, I solved the problem with FEED HOLD, so when i press it the spindle stops from rotation.The solution was a internal relay that needed to be activated.
  1. Replies: 5
    Last Post: 04-20-2019, 02:31 PM
  2. Replies: 4
    Last Post: 02-21-2019, 08:24 PM
  3. Replies: 28
    Last Post: 05-21-2015, 12:35 AM
  4. Fanuc series 21i-mb
    By schmitty9 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-18-2012, 08:40 PM
  5. Fanuc O-T Series B
    By yarpo in forum Fanuc
    Last Post: 09-24-2008, 12:13 PM
