I am trying to do a long distance diagnosis on a fanuc control M0. The programming software we are currently using outputs all programs in sub routines, Main program is O1000 acutal machining subs are named O3000, O3001 so forth and so on. When the operator tries to down load the program all sub routines are renamed to the windows file name. Example: File being transfered is named 16030_30mm.TF1. Notepad shows sub program name "On pc" as O3001. On control after download file reads O16031, incrementing the original program name by 1? it is really causing a problem with in the program and operator needs to rename each sub to correct format. In some cases this could be 100+ programs. Machine Info: control is a M0, file transfer software is a dos based software, running windows 98 "I think" on Pc. I am told there is a funuc parameter that controls this? anyone have a direction I can look in? I have no manuals for this machine and have never run this machine.
