587,481 active members*
2,793 visitors online*
    Fanuc Keep Relay?
    I work with a machine with a Fanuc control. It uses a number of Keep Relays to disable options in the PLC. I want to disable one of them mostly for diagnostic purposes, but after I force the Keep Relay, the machine resets it back to the original state after a power cycle. What do I have to do to make my change permanent?
    Aug 2019
    145
    Re: Fanuc Keep Relay?
    Keep Relays can be turned on and off through the ladder or if the OEM has generated custom screens through macro executer/Fanuc Picture.
    Search the address you are changing in the ladder and see if it appears. If it is found then a ladder edit would be required. If it isn't found and there is custom software it is most likely done there and can not be changed.
    Ex:
    K10 is the address you are working with
    K10.6
    Search K10.6 and see if there is a write (coil) for it.
    Also search K8, K9, K10 to see if a sub routine runs into K10.
    Quote Originally Posted by oetkbyentc View Post
    Ex:
    K10.6
    There is no coil for this keep relay in the PLC. It is only shows up once as a NC contact.
  1. Replies: 12
    Last Post: 01-30-2023, 01:23 PM
  2. Fanuc 18i-TB Keep Relay Will Not Change
    By rx8pilot in forum Fanuc
    Last Post: 01-08-2019, 10:32 PM
  3. Fanuc oimd milling keep relay
    By Nano-cr in forum Fanuc
    Last Post: 05-11-2017, 07:36 AM
  4. Citizen F12 Fanuc 3T Relay problems
    By amercc in forum Fanuc
    Last Post: 10-08-2013, 04:54 PM
  5. Using a solid state relay as a main stop relay
    By garagefela in forum CNC Machine Related Electronics
    Last Post: 02-26-2010, 11:27 PM
